Home > Puma (Tdci) > Turbo actuator plug
Primaryroo
England 2008 Defender 110 Puma 2.4 CSW Alpine White
Turbo actuator plug
Morning everybody, i wonder if anybody can give me some advice, bought a 2008 110 ( love her) drove about 300 mile then fault light came on. so as usual ordered a nanocom unit checked code and it was turbo over pressure,
once back in my garage and embarking on new swivel kits and balls and steering bars and steering box.....got to love it i checked the actuator nothing was happening. i gripped the wires to the plug and it stated moving ( broken wire ) rebuilt plug and took her to pick up my new caravan. she ran like a dream apart from smoke for the first mile then nothing.
picked caravan up and she drove like nothing was on the back. anyway after a long hill along the motorway she just lost power completely all gauges went mental so pulled over plugged nanocom in and turbo over pressure / high temp air inlet ....cleared code and tried to start and she sounded like a 2 stroke needing more choke, turned off and back on and she was 100% after 19 mile it done it again but after 10 seconds she was fine.
l left nanocom plugged in and she was reaching 110 c on hills then dropping to 89 instantly after hills.
my thoughts are
1. crap from turbo has fouled egr
2. egr heating water too much
can i get a patch to blank egr through nanocom and delete mechanivally and softwary lol
or is this something else.......head gasket seems fine lots of pressure
any thought would be greatly appreciated series 2a 1966
defender 90 1991
discovery 3 2005
discovery 2 2003
defender puma 110 2008
defender puma ex scottish power 2.4 2011
Post #855761 13th Sep 2020 6:14am
Dinnu
This thread might help: https://www.defender2.net/forum/topic73806...verheating
I would investigate why the temperature is climbing to 110dC first and foremost. since temperature drops to 90dc when there is less load, then it points to poor heat dissipation.. check radiator for clogging with leaves, dirt etc.
Good to check the viscous coupling on the radiator fan making sure that it draws enough air.
Coolant level is correct. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #855763 13th Sep 2020 6:34am
jst
Is it getting hot due to excess fuel incease in egt from turbo issues still. What boost is being made at fault occurrence point? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #855781 13th Sep 2020 10:18am
Primaryroo
well got bored and investigated.
took rad out cleaned through outside and in, loads of mud in veins
changed fluid to high quality coolant
changed water pump
changed thermostat (original 2007)
found after searching online and found exact same thermostat for MG temp 78 degree (havent fitted ,,,,a just in case thingy
temp is now 10 degree lower and towed caravan, temp didnt go above 92 even going up steep long hill
temp gauge is physically lower on needle
fingers crossed ( also now have plugged egr back in so thats back in the loop )
it still cools down instanltly when load finnished (but am i being overly concerned due to nanocom instantly updating temp ) series 2a 1966
defender 90 1991
discovery 3 2005
discovery 2 2003
Post #858660 29th Sep 2020 6:40am
hank
Hope you've got it sorted. If it reoccurs have a look at my post here about "P0234-00 (28 ) turbo overboost condition" error and the steps I took to sort it
https://www.defender2.net/forum/topic53240-113.html > 110 XS Double Cab
Post #858686 29th Sep 2020 9:20am
