Home > Puma (Tdci) > 110 Springs and Shocks - A little help...
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi all! Very Happy
Due to corroding springs and turrets, yesterday I changed the springs, shocks, turrets and seats on my 2010 110 Defender Utility.
I fitted yellow yellow and white white springs as per my research, but to my surprise found both driver and passenger side springs were white white. Not sure if they just ran out of yellow springs one day? Whistle
Anyway, my main question is based on the shock absorbers as I think I've fitted the wrong ones. Whilst the new ones seemed to be the same diameter and of course the same fittings as the old ones, they were a little softer. To be honest, this suited me as I do find the front end a little 'hard' compared to the back which are shod with Koni adjustable shocks (adjusted right out for comfort).
However it niggled me and last night I did my research again and realised I'd written down the wrong part number. I was hoping someone here could verify the difference between the two as this is bugging me now and I think I should change them. Part numbers are:
RSC100050 (what I fitted)
RSC500290 (what I should have fitted)
Any help appreciated before I waste money/time changing them if it's not needed Smile thanks! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #847696 2nd Aug 2020 9:47pm
The 050 one is for TD5 era vehicles whilst the 290 one is for post '07 vehicles. I wouldn't have imagined that there would have been that much difference to be honest, but it does appear that you've fitted the wrong ones. Darren
Post #847728 3rd Aug 2020 8:02am
jst
are the latters gas shocks too? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #847733 3rd Aug 2020 8:19am
ozzie1989
Good shout, not sure but will have a look.
I'm interested to see if the sizes and travel are the same or similar but will probably end up changing them to put my mind at rest Big Cry Now: 2010 2.4 TDCi 110 Utility Wagon
Post #847843 3rd Aug 2020 6:20pm
ozzie1989
Due to the fact that the earlier unit comes compressed and stays compressed, can we assume this is oil?
The later ones come extended and, I assume like the originals, extend themselves when not under compression. Does this mean they are gas?
Still can't find any comparative specs although the later ones come with 3 nuts instead of two which is interesting! Now: 2010 2.4 TDCi 110 Utility Wagon
Post #847848 3rd Aug 2020 6:32pm
MK
All of them have oil. Some have std P air and others pressurised N (plus some air). Puma 110" SW
Post #847930 4th Aug 2020 4:11am
ozzie1989
Yes that's correct, I should have been more clear Thumbs Up
In that case I will change them as the addition of gas is a positive Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Post #847932 4th Aug 2020 6:59am
MK
TBH I cannot understand how Defenders came out of the factory with "std oil shocks" for decades and suddenly, gas charged dampers is the way to go. Even today, the best dampers for heavily loaded Defenders are Koni Raid without N pressure. Puma 110" SW
Post #848303 6th Aug 2020 2:32am
ozzie1989
I have Koni HT adjustable shocks on the rear. I always thought they were gas filled but you've got me thinking now... Now: 2010 2.4 TDCi 110 Utility Wagon
Post #848309 6th Aug 2020 7:37am
MK
Koni HT Raid are filled with N. Koni Raid are not. Puma 110" SW
Post #848377 6th Aug 2020 2:06pm
ozzie1989
Hi all, new shocks have arrived.
They came with 3 nuts each, 1 large shouldered nut and 2 standard nuts, which has confused me slightly. Any ideas why?
Thanks Thumbs Up
Post #848695 8th Aug 2020 6:28pm
