|  | Home > Puma (Tdci) > 110 Springs and Shocks - A little help... |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | The 050 one is for TD5 era vehicles whilst the 290 one is for post '07 vehicles. I wouldn't have imagined that there would have been that much difference to be honest, but it does appear that you've fitted the wrong ones. Darren
 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  3rd Aug 2020 7:02am |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | are the latters gas shocks too? Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  3rd Aug 2020 7:19am |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282      | Good shout, not sure but will have a look.
 I'm interested to see if the sizes and travel are the same or similar but will probably end up changing them to put my mind at rest  Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) | ||
|  3rd Aug 2020 5:20pm |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282      | Due to the fact that the earlier unit comes compressed and stays compressed, can we assume this is oil?
 The later ones come extended and, I assume like the originals, extend themselves when not under compression. Does this mean they are gas? Still can't find any comparative specs although the later ones come with 3 nuts instead of two which is interesting! Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) | ||
|  3rd Aug 2020 5:32pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | All of them have oil. Some have std P air and others pressurised N (plus some air). Puma 110" SW
 ............................................................. Earth first. Other planets later | ||
|  4th Aug 2020 3:11am |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282      | Yes that's correct, I should have been more clear     In that case I will change them as the addition of gas is a positive  Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) | ||
|  4th Aug 2020 5:59am |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | TBH I cannot understand how Defenders came out of the factory with "std oil shocks" for decades and suddenly, gas charged dampers is the way to go. Even today, the best dampers for heavily loaded Defenders are Koni Raid without N pressure. Puma 110" SW
|  6th Aug 2020 1:32am |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282      | I have Koni HT adjustable shocks on the rear. I always thought they were gas filled but you've got me thinking now... Now: 2010 2.4 TDCi 110 Utility Wagon
|  6th Aug 2020 6:37am |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | Koni HT Raid are filled with N. Koni Raid are not. Puma 110" SW
|  6th Aug 2020 1:06pm |
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282      | Hi all, new shocks have arrived.
 They came with 3 nuts each, 1 large shouldered nut and 2 standard nuts, which has confused me slightly. Any ideas why? Thanks    Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) | ||
|  8th Aug 2020 5:28pm |
| Posting Rules
