|  | Home > Puma (Tdci) > Bad earth on rear lights circuit? |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | Main earthing point on bulkhead, somewhere by the master cylinders
 Bulkhead to chassis strap by gearbox bell housing Chek main earth by battery box Whilst your under and if you've the parts - add some more! Keith | ||
|  18th Jul 2020 5:12pm |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | Thanks Keith - will have a look at them tomorrow, anyone think it might be the brake light switch shorting? worth changing anyway? | ||
|  18th Jul 2020 5:45pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | You can try adding temporary ground leads too just to see if any change occurs. If it does, you’ll know the culprit to fix right away. ____\We|Will|Win/___
 ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ | ||
|  18th Jul 2020 7:16pm |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | Thanks Steve - if you don't mind how/where could I add a temp earth ? | ||
|  18th Jul 2020 7:43pm |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | Just run a wire from the -ve battery to tow socket -ve or the bulkhead multi -ve point or into a lamp connector -ve.
 As you've been working around the bulkhead - I'd go there first! Good luck Keith | ||
|  18th Jul 2020 8:22pm |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | A~s an after thought, there was a post on here about a faulty tow socket causing all kinds of weirdness! | ||
|  18th Jul 2020 8:23pm |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | Thanks Keith! | ||
|  18th Jul 2020 9:07pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | As mentioned by Keith.
 I would remove your transfer box ground stud which is IIRC the RHS of the T box looking towards the front. Clean it and refit. I had this happen, where it was dirty but not tightened up after a clutch change. All the ground paths were disturbed and I had the whole dash light up like a Christmas tree and external lights if you braked or indicated. That being said, if you were working in a certain area and the issue developed after that then I’d definitely look there. Water in the tow socket or plug under wheel arch is possible too. I fitted an aftermarket tow socket with LED test lights and fully sealed it myself on mine. The actual culprit was the T box earth though. Have you had any clutch change or t box or similar items removed lately? Also worth checking the battery posts are tight too. Good luck. 👍🏻 ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ | ||
|  18th Jul 2020 9:42pm |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | Thanks Steve , It wasn't me that changed the clutch so a busy day tomorrow then but thats the joy of a Defender - plenty to learn and do - a hobby first, a car second   | ||
|  18th Jul 2020 10:32pm |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | scraped knuckles, dirty finger nails and empty wallet syndrome...... | ||
|  19th Jul 2020 8:42am |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | Or the other woman as my wife refers to it! always unhappy the other woman gets parcels when she doesn’t, she was heard to mutter to the children - and exactly why does it needs brakes     So, ran earth from -ve to tow bar -ve and ir worked - so I assume faulty earth somewhere   Cleaned the earthing strap to transmission - no joy Ran earthing strap from sub earth to tow bar which is grounded on the body - it worked So logic says -ve battery to chassis is good , its from chassis to rear wiring that is the problem ? So i need to trace that path | ||
|  19th Jul 2020 10:12am |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864      | Check multi point on bulkhead - mines LHD so not sure if its in the same place, but not far from main connector to rear loom.....
|  19th Jul 2020 10:19am |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | chassis loom is grounded on transfer box  LH or RH drive | ||
|  19th Jul 2020 10:52am |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123  | So transfer box stud and bulkhead multi stud cleaned and refitted - and still doesnt work - So I assume loom or switch? as an aside is not advisable to wire a new earth even if temporary? | ||
|  19th Jul 2020 12:00pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
