Home > Maintenance & Modifications > Roof lining fabric.
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Roof lining fabric.
Gents,
I have been putting sound deadening in the defender and had to remove the roof lining.
I’d like to buy new fabric for it.
Any ideas on what to buy?
Thank you
Fabio
Post #841763 4th Jul 2020 3:31pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I used this
https://www.fabricuk.com/fabrics/1397-audi-car-headlining.html
It was something different, and importantly wide enough!! Wasn't too hard to work with either - its not perfect, but for a DIY i was more than happy. More so the whole job cost me under 100, and the upholsterer I went to see wouldn't do it for less than 500, and with what i'd consider awfully cheap material.
Post #843635 14th Jul 2020 12:32pm
donmacn
Hi Fabio,
I did mine not so long ago and posted links and comments on this thread:
https://www.defender2.net/forum/topic72107.html
I think what I took from doing the work, and seeing others comments, is that having a 'four way stretch' material would make life a lot easier. And using 'high temperature' spray adhesive. I think (for a 110) I used about 4-5 tins of glue. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #843641 14th Jul 2020 12:55pm
Fabio
Thank you Gents.
I have done it now but i think i used the wrong fabric...
So now I am a bit stuck on how to sort it.
On some bits of it i didn't put enough glue, does anyone have any ideas as to how i can now glue it from the outside or maybe do something else?
Regards
Fabio
Post #843643 14th Jul 2020 1:03pm
donmacn
I've been trying to think what I'd do in this situation....
I've read that, for older, sagging headlining one approach is to cut a hole or 'flap' and then get some new glue underneath. But I feel as if that might be a temporary repair on old material which has already stretched - not sure I'd try it on newer stuff.
Sounds like a real hassle, but could you just start again?? Carefully cutting the material off and having another go at it with something different? Probably take a bit of time.
The other option would be to pick up a 'used' set of headlinings? It wouldn't matter if it was a bit grubby if you were planni g to redo it.
Sorry - don't think either of those suggestions are too easy. Donald
in the past..
Post #843766 14th Jul 2020 9:13pm
Fabio
Hello Sir,
I don't want to remove it again as it is fragile and it could start to break along with all the trimming.
I'm on holiday in a weeks time and then i'll have a good look at what i can do.
Fabio
Post #843813 15th Jul 2020 6:25am
zippo87
I’m with Don on this one - I think you’ll find any ‘patching’ of a repair quite frustrating, as you may loosen your glue as you work, and end up with further work to do. If you’ve you think you’ve used the wrong stuff and don’t like it just think it’ll be the first thing you ever look at when you jump in the landy 😂 better to start again, 1st time was just practice!!
Post #843864 15th Jul 2020 11:52am
Fabio
Laughing You are right but it isn’t an easy thing to do so it takes a bit of courage to take it all apart again...
Fabio
Post #843865 15th Jul 2020 11:57am
gilarion
Spotted this maybe still for sale a roll of genuine roof lining fasbric
https://www.defender2.net/forum/topic60502...ing+fabric For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #843892 15th Jul 2020 3:50pm
These guys seem to be the go-to giuys for headlining. I have recently bought some to re-upholster the headlining in my Disco 2, which is suffering from the usual failure of the backing foam.
I think the Defender material is slightly different to the Disco material, but I suspect that the failure mechanism is much the same. The accepted wisdom is that when it starts going you can't really do anything except replace it, since it is not the adhesive which fails, rather the foam layer that breaks down.
I had great service from Martrim, but I haven't yet had the time to do the job.
Post #843897 15th Jul 2020 4:05pm
Fabio
Thank you all.
I’ll have a look during the holidays and see what solution I find for it.
Fabio
Post #843925 15th Jul 2020 6:12pm
jst
the chap I use is taunton based, near creeh castle, he would be able to supply only i expect? Jason davies 07779303858 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #844014 16th Jul 2020 7:50am
Fabio
Thank you James.
I’ll see what I want to do.
Post #844020 16th Jul 2020 8:10am
bear100
I have seen one sprayed with one of the the paints from Buzzwelld (not to sure which one i think Plastic in a can?) and i was very impressed in fact it looked like it had always been black! 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #844027 16th Jul 2020 8:45am
Fabio
That is what I wanted to do.
But my wife Didn’t think it would be nice.
Fabio
Post #844029 16th Jul 2020 9:05am
