Home > Puma (Tdci) > How to remove the 2nd row seats from 110 - not the brackets |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Is there a particular reason to leave the brackets in? It's very easy to remove the seats with the brackets. 2007 110 TDCi Station Wagon XS
26th May 2020 4:32pm |
rizga1 Member Since: 14 Apr 2020 Location: QZ Posts: 28 |
I was planning of leaving the brackets in because I assume they probably bolt through the floor and leave a load of holes.
26th May 2020 4:54pm |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 147 |
If they’re anything like the tumbledown seats, removing the nut doesn’t allow the bracket to easily slide off the rod attached to the seat, they’re pressed on very firmly indeed (or at least mine were).
26th May 2020 5:09pm |
They do, but you can just put the bolts back in the holes. From memory it is a mixture of bolts and studs. 2007 110 TDCi Station Wagon XS |
26th May 2020 5:14pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 993 |
It is just the bolts and yes that spring is nasty Put some styrofoam or similar in the rear footwell to support the seat once it is off. It's a while back but I think I started removing the 4 screws, then folded the seat over then unscrewed the 2 nuts - while doing that be careful. I think it is the left hand side spring that wants to hit you. They "relax" into different positions. Ah, well.. I'll post some pictures As for the brackets, it's just 6 screws. Their nuts are below the floor and can slide to and fro (don't know how they are held in place exactly). Just put the screws back in, maybe add rubber washers. With our camper conversion I can put the seat back in if I need to. I made a cut out in the wooden floor for the brackets. However I mount it without the plastic cover. I cut off some pieces to have a smaller footprint. Oh, and you can't fully unfold the seat after removal. The bracket seems to unlock the folding mechanism somehow. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge - Click image to enlarge Click image to enlarge |
26th May 2020 6:07pm |
Well, following such a 'complete' reply it would be rude of me not to remove the brackets as well.
I will attack it tomorrow. Thank you everyone. |
26th May 2020 7:22pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
very simple to remove as above. if your leaving brackets in the lower of the two forward mounting bolts only needs to be undone, its a slotted fit. makes it easier to align them when refitting.
yes that spring is strong. A7E job when the wife was helping me lift seats out, well it would of been A&E but it was a weekend sowould of been busy and its miles from the house so i glued it back up. will never be quite right, should of been stitched. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
26th May 2020 8:50pm |
double post Cheers
26th May 2020 8:55pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Just to reiterate, they are bloody heavy, especially the 2/3rds bit
Get a helper and take care Keith |
26th May 2020 10:05pm |
