Home > Puma (Tdci) > How to remove the 2nd row seats from 110 - not the brackets
rizga1
I have had a search around on this topic but most of what I find relates to removal of the 3rd row seats or removal of the 2nd row seats including the floor brackets.
I am wondering how to just remove the 2nd row seats (or at least the 60% one) and I am not bothered about the brackets being left behind.
It looks as simple as just undoing the bolts that connect the seat bases to the floor brackets but there is a fairly stiff spring lurking there and I am worried what might happen once I get the spanners out Embarassed
Can anyone shed any light on this process, like is it safe or are there any precautions that I need to take. Also do they go back in alright or does the spring make life difficult.
Thank you in advance everyone.
Post #833451 26th May 2020 2:30pm
Bluest
Is there a particular reason to leave the brackets in? It's very easy to remove the seats with the brackets. 2007 110 TDCi Station Wagon XS
Post #833482 26th May 2020 4:32pm
rizga1
I was planning of leaving the brackets in because I assume they probably bolt through the floor and leave a load of holes.
Post #833486 26th May 2020 4:54pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
If they’re anything like the tumbledown seats, removing the nut doesn’t allow the bracket to easily slide off the rod attached to the seat, they’re pressed on very firmly indeed (or at least mine were).
Post #833490 26th May 2020 5:09pm
Bluest
They do, but you can just put the bolts back in the holes. From memory it is a mixture of bolts and studs. 2007 110 TDCi Station Wagon XS
Post #833491 26th May 2020 5:14pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Re: How to remove the 2nd row seats from 110 - not the brack
It is just the bolts and yes that spring is nasty Smile
Put some styrofoam or similar in the rear footwell to support the seat once it is off.
It's a while back but I think I started removing the 4 screws, then folded the seat over then unscrewed the 2 nuts - while doing that be careful. I think it is the left hand side spring that wants to hit you. They "relax" into different positions. Ah, well.. I'll post some pictures Smile
As for the brackets, it's just 6 screws. Their nuts are below the floor and can slide to and fro (don't know how they are held in place exactly). Just put the screws back in, maybe add rubber washers.
With our camper conversion I can put the seat back in if I need to. I made a cut out in the wooden floor for the brackets. However I mount it without the plastic cover. I cut off some pieces to have a smaller footprint.
Oh, and you can't fully unfold the seat after removal. The bracket seems to unlock the folding mechanism somehow.
Post #833496 26th May 2020 6:07pm
rizga1
Well, following such a 'complete' reply it would be rude of me not to remove the brackets as well.
I will attack it tomorrow.
Thank you everyone.
Post #833521 26th May 2020 7:22pm
jst
very simple to remove as above. if your leaving brackets in the lower of the two forward mounting bolts only needs to be undone, its a slotted fit. makes it easier to align them when refitting.
yes that spring is strong. A7E job when the wife was helping me lift seats out, well it would of been A&E but it was a weekend sowould of been busy and its miles from the house so i glued it back up. will never be quite right, should of been stitched. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833557 26th May 2020 8:50pm
jst
double post Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833560 26th May 2020 8:55pm
ickle
Just to reiterate, they are bloody heavy, especially the 2/3rds bit
Get a helper and take care
Keith
Post #833583 26th May 2020 10:05pm
