![]() | Home > eBay & Bargain Spots > defender 6x6 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
https://www.ebay.co.uk/itm/Land-Rover-Defe...SwZxZesFih
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
Will he throw the rust in for free....
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17885 ![]() ![]() ![]() |
Not really a 6x6 when it only has 4 wheel drive, is it. A bit like saying a write-off was in good condition before the accident!
I doubt spares for through-drive axles are easy to find. |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
You'd get a nice load of thatch in the back of that Clayton...
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1785 ![]() ![]() ![]() |
I'd assume (knowing nothing about them) that it wouldn't be too much of a difficult task to remanufacture them if the buyer had turning/milling equipment? Agreed that a 6x4 is fairly pointless though!! |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 689 ![]() ![]() ![]() |
You would have thought so as you aren't getting an air filter! |
I imagine that fabricating a drive-through diff from scratch is actually rather difficult, it's worth a Google to see what is involved. I suspect that the drive-through diff assembly would have been the most valuable part of that vehicle, if only it was still there! |
They do seem to be available though. I saw a picture posted by Foleys only recently of a pallet load of thru-drive axles. Darren
Yes i would Nidge ![]() Would love to have one of them as a work vehicle ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
I'm fairly confident that that doesn't have a through drive diff. That rear axle is on backwards and has been modified to do so (dampers facing forwards but diff flange facing rearward).
Looks to me like it's meant to have a splitter box on the middle axle and then another propshaft from that. It's certainly not the same setup as my 6x6 which does have a through drive. ![]() Click image to enlarge ![]() Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
I was going off the description -
I appreciate that but looking at the pictures it doesn't tie up with the setup on my Sandringham which genuinely takes drive through the diff pumpkin. It looks a bit more like a Foley setup which takes drive over the diff and back in through the rear. Ed
It's quite possible that the seller doesn't know what he's talking about. It wouldn't be the first time on eBay!
