Home > eBay & Bargain Spots > defender 6x6
L110CDL
defender 6x6
https://www.ebay.co.uk/itm/Land-Rover-Defe...SwZxZesFih
Thumbs Up Clayton.
Keeper.
Post #829295 4th May 2020 9:26pm
markb110
Will he throw the rust in for free.... Shocked
Post #829306 4th May 2020 10:10pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I bet foleys would snap that up, they seem to have done a few 6x6 rebuilds. Never to rusty for them either as everything gets replaced with galv bits.
Post #829318 4th May 2020 10:43pm
Not really a 6x6 when it only has 4 wheel drive, is it. A bit like saying a write-off was in good condition before the accident!
I doubt spares for through-drive axles are easy to find.
Post #829319 4th May 2020 10:59pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
You'd get a nice load of thatch in the back of that Clayton... Laughing
Post #829330 5th May 2020 7:40am
miker
I'd assume (knowing nothing about them) that it wouldn't be too much of a difficult task to remanufacture them if the buyer had turning/milling equipment?
Agreed that a 6x4 is fairly pointless though!!
Post #829348 5th May 2020 10:27am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
You would have thought so as you aren't getting an air filter!
Post #829352 5th May 2020 11:00am
I imagine that fabricating a drive-through diff from scratch is actually rather difficult, it's worth a Google to see what is involved. I suspect that the drive-through diff assembly would have been the most valuable part of that vehicle, if only it was still there!
Post #829360 5th May 2020 11:33am
They do seem to be available though. I saw a picture posted by Foleys only recently of a pallet load of thru-drive axles. Darren
Post #829365 5th May 2020 11:55am
L110CDL
Yes i would Nidge Thumbs Up
Would love to have one of them as a work vehicle Very Happy Clayton.
Keeper.
Post #829419 5th May 2020 8:33pm
sako243
I'm fairly confident that that doesn't have a through drive diff. That rear axle is on backwards and has been modified to do so (dampers facing forwards but diff flange facing rearward).
Looks to me like it's meant to have a splitter box on the middle axle and then another propshaft from that. It's certainly not the same setup as my 6x6 which does have a through drive.
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #829448 5th May 2020 11:29pm
I was going off the description -
The seller wrote:
... currently a 6x4 as the middle axle broke so casing was moved to the rear
and a salisbury axle fitted to the centre, can be swapped back if the through drive axle pieces were found ...
Post #829454 6th May 2020 7:15am
sako243
I appreciate that but looking at the pictures it doesn't tie up with the setup on my Sandringham which genuinely takes drive through the diff pumpkin. It looks a bit more like a Foley setup which takes drive over the diff and back in through the rear. Ed
Post #829463 6th May 2020 8:35am
It's quite possible that the seller doesn't know what he's talking about. It wouldn't be the first time on eBay!
Post #829470 6th May 2020 9:00am
