Home > Td5 > Bolt thread size please
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all,
Due to still having a VERY basic tool kit still ( rest in storage )
The four bolts that are in a square pattern that hold on the plastic facia around the headlamps and front lights on a TD5
What thread size are they ? I’m guessing M4 maybe ?
I’m ordering up some black stainless mushroom headed ones to replace the std manly ones at present,
Thanks in advance folks & stay safe out there Thumbs Up
Post #828918 2nd May 2020 5:49pm
ickle
Big self tappers?
Post #828922 2nd May 2020 5:59pm
discomog
No8 x1/2inch Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #828925 2nd May 2020 6:14pm
Daisy90
Defo not self tappers,
And what does no8 mean ? The only no8 I know is in wood screws Thumbs Up
It’s a normal wind in bolt, just not got nothing available to measure it
Thanks for the time in replying Thumbs Up
Post #828961 2nd May 2020 9:38pm
Martin
Site Admin
Looking at this photo from your gallery, this is a non-standard fitting method. Hex-head bolts/screws have been used instead of the originals between the headlamp and the grille, plus an extra two between the headlamp and the signal lamps which aren't there as standard.
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #828963 2nd May 2020 9:48pm
apachecow
1999 Defender 110 Td5 CSW Rutland Red
I can thoroughly recommend a set of these:
https://www.rutlands.co.uk/sp+hand-tools-m...nds+dk7026
They come up on offer from time to time
Post #828969 2nd May 2020 10:21pm
Daisy90
It came from the factory / dealer with plastic covers to protect the headlamps, so that’s why it has the extra fixings , sadly it was three weeks old when a pheasant took them out Rolling Eyes
Post #828978 2nd May 2020 11:37pm
ARC99
M8 means dia of threaded section is 8mm in dia.
The bolt head should be fit a 13mm spanner but knowing Land Rover it could be any size.
edited to correct spanner size from 10 to 13 mm. Don't make old people mad.
Richard
Post #828994 3rd May 2020 8:31am
Mo Murphy
A standard M8 has a 13mm head size. Wink
Self-tapping screws are similarly sized to wood screws by number.
50 Shades of Pennine Grey
Post #828995 3rd May 2020 8:44am
ARC99
Mo, yes you are correct , I should have put brain into right gear 10mm is for a M6 head. Don't make old people mad.
Richard
Post #828997 3rd May 2020 8:48am
Daisy90
That are a 10mm socket size, so thinking 6mm thread ?
Post #829038 3rd May 2020 4:58pm
ARC99
I would take one out and measure the diameter, I have removed over the last week or two that I thought would be M6 bolts only to find they were in fact M8 with a smaller hex head. When I was in engineering we called them lost heads. Don't make old people mad.
Richard
Post #829074 3rd May 2020 7:49pm
