![]() | Home > Td5 > Bolt thread size please |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1855 ![]() ![]() ![]() |
Big self tappers?
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
No8 x1/2inch Defender 90XS SW
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Defo not self tappers,
And what does no8 mean ? The only no8 I know is in wood screws ![]() It’s a normal wind in bolt, just not got nothing available to measure it Thanks for the time in replying ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
Looking at this photo from your gallery, this is a non-standard fitting method. Hex-head bolts/screws have been used instead of the originals between the headlamp and the grille, plus an extra two between the headlamp and the signal lamps which aren't there as standard.
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 ![]() ![]() |
I can thoroughly recommend a set of these:
https://www.rutlands.co.uk/sp+hand-tools-m...nds+dk7026 They come up on offer from time to time |
It came from the factory / dealer with plastic covers to protect the headlamps, so that’s why it has the extra fixings , sadly it was three weeks old when a pheasant took them out
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
M8 means dia of threaded section is 8mm in dia. The bolt head should be fit a 13mm spanner but knowing Land Rover it could be any size. edited to correct spanner size from 10 to 13 mm. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard Last edited by ARC99 on 3rd May 2020 8:47am. Edited 1 time in total |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2345 ![]() ![]() ![]() |
A standard M8 has a 13mm head size.
![]() Self-tapping screws are similarly sized to wood screws by number. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Mo, yes you are correct , I should have put brain into right gear 10mm is for a M6 head. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
That are a 10mm socket size, so thinking 6mm thread ?
I would take one out and measure the diameter, I have removed over the last week or two that I thought would be M6 bolts only to find they were in fact M8 with a smaller hex head. When I was in engineering we called them lost heads. Don't make old people mad.
