Home > My Defender > a 130 itch
Page 14 of 23 <123 ... 131415 ... 212223>
Thon
You've done a great job with that 130 James - I'm really impressed with the thought and hard work you've put into it. I've always had a soft spot for 130s since working on them in the 90s. Pretty much the perfect Defender IMHO Thumbs Up
Post #859247 2nd Oct 2020 8:34am
jst
Thank you,
Have to be honest in that i thought it was going to be too big for daily use. i have out 3k miles on it since the conversion and been using it as a daily drive for the last week and actually is no different to my 110 in reality. its tight in places, but so the 110. lock is the same, turning circle not that much more, just uses a touch more fuel, on the plus side ride is nice and tows very well. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859278 2nd Oct 2020 10:12am
jst
130 working well last few days, slight water leak through bulkhead needs to be sorted. Getting around 25mpg with mixed use including towing around 1.5t avg.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859781 4th Oct 2020 5:24pm
L110CDL
Your 130 makes the trailer look very small Smile Clayton.
Keeper.
Post #860346 7th Oct 2020 8:46pm
jst
It is only a gd85! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861459 13th Oct 2020 9:17pm
jst
First day out driving guns around on the local shoot yesterday, they are all loving the rear legroom!
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #861672 15th Oct 2020 8:01am
jst
Replacement gbox, ashcroft intermediate upgrade shaft and 1.3 ratio lt230 arriving soon! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #862266 18th Oct 2020 4:31pm
jst
Thank you Ashcrofts. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #862460 19th Oct 2020 4:32pm
Mdm
more work but worth it.
cant wait to have a drive in it
Post #862503 19th Oct 2020 9:21pm
jst
There's a queue at the moment. On the last shoot day where I provided transport, guns immediately booked inntheir seat for next time. 1.3 box will help when towing . Its going to have to wait a little while bit busy.com at moment with it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #862540 20th Oct 2020 7:49am
jst
Well this fell out today, just helping the spigot bearing put of the crank currently, then ready for refit.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #866376 9th Nov 2020 9:11pm
jst
Well this little gritter proved to be a rpita.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #866553 10th Nov 2020 8:37pm
jst
reconditioned gearbox and 1.3 ratio T box is in. despite the spigot bearing taking 2hrs to remove it was relatively straight forward. Clutch changed at the same time. Great to see whoever did the clutch last time didnt both refitting all the bell housing bolts (under the EGR cooler!)
only driven it 30miles or so, i need to sort the gearchange selection, hence my other post about the spacers here: https://www.defender2.net/forum/topic29132.html and this tech bulletin https://www.defender2.net/gallery/albums/u...uality.pdf
ratio wise, really happy with it, 130 is part loaded, probably 200kg in the back plus the conversion weight, and with the 1.3 it drives like my 110 on a 1.2 box. very pleased with the result. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #866816 11th Nov 2020 8:37pm
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi James
Any more details / pics of the rear tank guard / tow bar setup?
I have what I believe is the same tank guard/detachable tow pack and recovery eye from my 110 (Southdown from memory?) that I was wanting to fit but wasn't sure of the best way to extend the mounting point for the tow ball to get it back to the original(ish) position.
Thanks
Ben
Post #867088 13th Nov 2020 3:06pm
jst
Hi Ben, yes its a Southtown one. Are you talking about extending it for a 130 specific use? Do you have the original tow plate attachment? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #867144 13th Nov 2020 7:43pm
