Home > Puma (Tdci) > Gauge Inpiration
90 Dreamer
Gauge Inpiration
had a bit of a search but can't seem to find what i thought i had seen..........
looking at possibly installing a 52mm gauge and was wondering about location / mounting ideas??
probably only the one and don't have plans for anymore...
Post #817524 29th Feb 2020 1:53pm
discomog
It would be an advantage to know what dash you intend fitting it in, on or under, 300Tdi, Td5, Puma etc. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #817546 29th Feb 2020 5:05pm
DSC-off
For a single gauge that won't clutter up the dash, it's possible to fit a pod to the headling between the mirror and light.
I repositioned the clock in my TD5 up there to make space for a rev counter.
Wires can be fully concealed behind the headlining and pillar trims.
One of these, upside down.
For more than one gauge, or extra switches, Mud UK do dash pods.
Post #817547 29th Feb 2020 5:07pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
RDX ABS version:-
[/url]https://www.ebay.co.uk/itm/RDX-Top-Pod-for-Land-Rover-Defender-Puma-2-2-2-4-Tdci-Switch-Panel-Dashboard-/361860347039[url]
Raptor steel/aluminium version:-
https://www.raptor-engineering.co.uk/product/defender-pod
Post #817549 29th Feb 2020 5:13pm
90 Dreamer
Sorry its for a late model PUMA.........
On,y after fitting one gauge so definately don't need a huge pod ont he dash, thought i had seen a different side panel at the side of the radio??
Post #817695 1st Mar 2020 11:41am
NeinFondue
You can see here the side switch panel that comes with the double din conversion fascia. I think you can also buy just the side panel from Twisted or Powerfuluk.
Post #818650 7th Mar 2020 5:12pm
NeinFondue
Post #818651 7th Mar 2020 5:13pm
90 Dreamer
Do you have to cut the side panel to fit and can you get just a gauge panel or do you have to have the extra multi switch blanks??
Post #818659 7th Mar 2020 6:20pm
NeinFondue
Yes, you have to cut the dash to install switches / gauges / switch panels. Dunno if you can get just a gauge panel.
Post #818661 7th Mar 2020 6:25pm
Vitesse
I used a mud pod for my application as needed some switches. But maybe an overkill for just one gauge
 2015 90 XS Santorini Black
Post #818668 7th Mar 2020 7:14pm
90 Dreamer
Definitely dont want a pod on top and not really keen on those Twosted type side panels as will just have millions of blanks........
Looking like will have to do something as a 'one-off'
Thanks for the pix
Post #818672 7th Mar 2020 7:23pm
LR90XS2011
what are you trying to display on the gauge DEFENDER 90 TDCI XS,
Post #818680 7th Mar 2020 8:00pm
90 Dreamer
Most likley a dual gauge for temps.......
Just a stupid thing but i find an extrenal temp gauge in particular really useful and pretty much all of my other vehicles have this from the factory
Post #818688 7th Mar 2020 8:27pm
Matt110
Not sure I'd do that with a round 52mm gauge though personally am after a battery management system in that size, checktemp2? Might save you the whole issue as it fits in a much smaller surface area?
Post #818691 7th Mar 2020 8:47pm
hornet
I agree, i did that months ago. I fitted oiltemperature and -prsssure in the sidepanel, mine is a LHD. Another feature is that it shows you Voltage from time to time and switches back to original value. to be honest, it does not look as nice as an analogue device; There is place for a third one, I thought about exhaust-temperature before turbo. But that means to measuer inside header and I have no good idea for implementing it without risk of cracks...
Post #819269 12th Mar 2020 2:13pm
