Home > Puma (Tdci) > Gauge Inpiration |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
It would be an advantage to know what dash you intend fitting it in, on or under, 300Tdi, Td5, Puma etc. Defender 90XS SW
29th Feb 2020 5:05pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1351 |
For a single gauge that won't clutter up the dash, it's possible to fit a pod to the headling between the mirror and light.
I repositioned the clock in my TD5 up there to make space for a rev counter. Wires can be fully concealed behind the headlining and pillar trims. One of these, upside down. Click image to enlarge For more than one gauge, or extra switches, Mud UK do dash pods. |
29th Feb 2020 5:07pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
RDX ABS version:-
[/url]https://www.ebay.co.uk/itm/RDX-Top-Pod-for-Land-Rover-Defender-Puma-2-2-2-4-Tdci-Switch-Panel-Dashboard-/361860347039[url] Raptor steel/aluminium version:- https://www.raptor-engineering.co.uk/product/defender-pod |
29th Feb 2020 5:13pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2054 |
Sorry its for a late model PUMA.........
On,y after fitting one gauge so definately don't need a huge pod ont he dash, thought i had seen a different side panel at the side of the radio?? |
1st Mar 2020 11:41am |
NeinFondue Member Since: 07 Mar 2020 Location: Berkshire Posts: 6 |
You can see here the side switch panel that comes with the double din conversion fascia. I think you can also buy just the side panel from Twisted or Powerfuluk.
7th Mar 2020 5:12pm |
Click image to enlarge |
7th Mar 2020 5:13pm |
Do you have to cut the side panel to fit and can you get just a gauge panel or do you have to have the extra multi switch blanks??
7th Mar 2020 6:20pm |
Yes, you have to cut the dash to install switches / gauges / switch panels. Dunno if you can get just a gauge panel.
7th Mar 2020 6:25pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
I used a mud pod for my application as needed some switches. But maybe an overkill for just one gauge
Click image to enlarge 2015 90 XS Santorini Black |
7th Mar 2020 7:14pm |
Definitely dont want a pod on top and not really keen on those Twosted type side panels as will just have millions of blanks........
Looking like will have to do something as a 'one-off' Thanks for the pix |
7th Mar 2020 7:23pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
what are you trying to display on the gauge DEFENDER 90 TDCI XS,
7th Mar 2020 8:00pm |
Most likley a dual gauge for temps.......
Just a stupid thing but i find an extrenal temp gauge in particular really useful and pretty much all of my other vehicles have this from the factory |
7th Mar 2020 8:27pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 673 |
Not sure I'd do that with a round 52mm gauge though personally am after a battery management system in that size, checktemp2? Might save you the whole issue as it fits in a much smaller surface area?
7th Mar 2020 8:47pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 325 |
I agree, i did that months ago. I fitted oiltemperature and -prsssure in the sidepanel, mine is a LHD. Another feature is that it shows you Voltage from time to time and switches back to original value. to be honest, it does not look as nice as an analogue device; There is place for a third one, I thought about exhaust-temperature before turbo. But that means to measuer inside header and I have no good idea for implementing it without risk of cracks... Click image to enlarge |
12th Mar 2020 2:13pm |
