![]() | Home > Puma (Tdci) > Gauge Inpiration |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
Why not just fit an ultraguage?
It can just sit behind the wheel or some folk have built into the dash. You can choose upto 8 different gauges to show on one screen. Click image to enlarge |
| NeinFondue Member Since: 07 Mar 2020 Location: Berkshire Posts: 6
I have an ultra gauge, but I’m pretty sure it doesn’t do oil pressure.
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 |
Easy, see picture. For oiltemperature I soldered the threaded socket into the oilpan, I did not want to have a solution combined with the drain plug... Click image to enlarge |
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
I also use an ultra gauge very successfully. Also, Oil temperature taken from a sensor screwed into a boss braised in to the sump and the gauge sits in a mud pod
Does the ultra gauge read oil pressure over OBD on the Puma??
No oil pressure unfortunately 2015 90 XS Santorini Black
| All times are GMT |
