Home > Puma (Tdci) > Gauge Inpiration
Page 2 of 2 <12
NeinFondue
I’m quite keen on adding an oil pressure gauge as well. How easy was it to fit, and where did you install your sensor / sender unit?
Post #819282 12th Mar 2020 3:31pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Why not just fit an ultraguage?
It can just sit behind the wheel or some folk have built into the dash.
You can choose upto 8 different gauges to show on one screen.
Post #819298 12th Mar 2020 5:30pm
NeinFondue
I have an ultra gauge, but I’m pretty sure it doesn’t do oil pressure.
Post #819301 12th Mar 2020 5:38pm
hornet
Easy, see picture. For oiltemperature I soldered the
threaded socket into the oilpan, I did not want to have a solution combined with the drain plug...
Post #819309 12th Mar 2020 6:35pm
Vitesse
I also use an ultra gauge very successfully. Also, Oil temperature taken from a sensor screwed into a boss braised in to the sump and the gauge sits in a mud pod Thumbs Up 2015 90 XS Santorini Black
Post #819340 12th Mar 2020 9:11pm
NeinFondue
Does the ultra gauge read oil pressure over OBD on the Puma??
Post #819346 12th Mar 2020 9:25pm
Vitesse
No oil pressure unfortunately 2015 90 XS Santorini Black
Post #819377 13th Mar 2020 12:20am
Page 2 of 2 <12
