Home > Maintenance & Modifications > LED Sidelights
chrispaylin93
United Kingdom 2005 Defender 110 Td5 XS DCPU Santorini Black
LED Sidelights
Hello hello,
I have installed LED sidelights on the front and back of my defender, after doing so when I put the light switch to sidelights it also puts power to headlights!
Is there any way of stopping this?
T.I.A Very Happy Very Happy [/quote]
Post #811403 21st Jan 2020 11:26pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Are your headlights running on relays?
Either way, there is a resistor which gives a small amount of power to the headlights when the switch is set for sidelight only, you can disconnect it by bypassing the relay behind the dash or disconnecting the resistor.
https://www.defender2.net/forum/post314514.html
Post #811879 25th Jan 2020 2:07pm
^^^^ This. I believe IIRC I had the same issue. Disconnecting the resistor did the trick. Then I fitted sealed blanks to the plugs to seal off once disconnected. Under the drivers side wing on a RHD and a 2 pole econoseal connector if I remember rightly. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #811909 25th Jan 2020 4:58pm
NMBRPL8
Australia
Don't mean to derail the thread but always thought the front side lights would make suitable DRLs.
Is this a common mod?
Post #812044 26th Jan 2020 2:09pm
Mo Murphy
Not really common but I've done it.
50 Shades of Pennine Grey
Post #812060 26th Jan 2020 3:55pm
chrispaylin93
Thanks for your help Very Happy
Post #813018 1st Feb 2020 9:40am
