![]() | Home > Maintenance & Modifications > LED Sidelights |
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
Are your headlights running on relays?
Either way, there is a resistor which gives a small amount of power to the headlights when the switch is set for sidelight only, you can disconnect it by bypassing the relay behind the dash or disconnecting the resistor. https://www.defender2.net/forum/post314514.html |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
^^^^ This. I believe IIRC I had the same issue. Disconnecting the resistor did the trick. Then I fitted sealed blanks to the plugs to seal off once disconnected. Under the drivers side wing on a RHD and a 2 pole econoseal connector if I remember rightly. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 150
Don't mean to derail the thread but always thought the front side lights would make suitable DRLs.
Is this a common mod? |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2417
Not really common but I've done it.
| chrispaylin93 Member Since: 13 May 2017 Location: Gloucestershire Posts: 14
Thanks for your help
| All times are GMT |
