Home > In Car Electronics > 10AS Delete
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
10AS Delete
Hello Def2 Team,
I’m looking at options to remove the weak point that is the 10AS module. I also have a Toad alarm system on my 110. This means carrying around 2 fobs, until the 10AS fails at least!
I’ve found the following possible solution and would welcome any thoughts from forum elders:
[url] https://www.m1n1.de/en/remove-rover-lucas-...zer/[/url]
Anyone have experience of this or any other better solution?
Yours,
NG
Post #809644 10th Jan 2020 7:10am
dorsetsmith
Anyone have experience of this or any other better solution not but have bad experience with https://www.technozen-electronics.co.uk/la...-services/
Post #809648 10th Jan 2020 8:09am
excossack
Can the 10AS just be removed from the ECU programming i.e no fob needed? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #809653 10th Jan 2020 9:41am
X4SKP
Second endorsement for https://www.technozen-electronics.co.uk/la...-services/
Talk to Paul Brown... he really knows the Lucus 10AS and in my experience will
give you sound advice.
I explored a possible fault with mine... that was not there, finding the fault elsewhere...
what I didn't get was rip it out and start again, I would say he has a realistic take on it,
good and bad, what is possible and how to do it.
Good Luck... SKIP
Post #809655 10th Jan 2020 10:08am
dorsetsmith
Not from TD5 ECU if no fob needed 10AS can be programmed spider so that engine will start from key only
as to ford LR engine ecu if no fob needed 10AS can be programmed spider so that engine will start from key only
Post #809658 10th Jan 2020 10:37am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
My as10 is also programmed so I don't need a fob. Bell Autoservice can do something with the ECU so it doesn't look for the AS10 so you can get rid of it alltogether. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #809691 10th Jan 2020 5:43pm
Not_Given
Thanks, all. Looks like some good options there. Definitely want rid, so may give BAS a call.
Post #809754 11th Jan 2020 7:43am
