Home > In Car Electronics > 10AS Delete |
Not_Given Member Since: 25 Dec 2017 Location: UK Posts: 80 |
Hello Def2 Team,
I’m looking at options to remove the weak point that is the 10AS module. I also have a Toad alarm system on my 110. This means carrying around 2 fobs, until the 10AS fails at least! I’ve found the following possible solution and would welcome any thoughts from forum elders: [url] https://www.m1n1.de/en/remove-rover-lucas-...zer/[/url] Anyone have experience of this or any other better solution? Yours, NG |
10th Jan 2020 7:10am |
Anyone have experience of this or any other better solution not but have bad experience with https://www.technozen-electronics.co.uk/la...-services/
10th Jan 2020 8:09am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2289 |
Second endorsement for https://www.technozen-electronics.co.uk/la...-services/
Talk to Paul Brown... he really knows the Lucus 10AS and in my experience will give you sound advice. I explored a possible fault with mine... that was not there, finding the fault elsewhere... what I didn't get was rip it out and start again, I would say he has a realistic take on it, good and bad, what is possible and how to do it. Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
10th Jan 2020 10:08am |
Not from TD5 ECU if no fob needed 10AS can be programmed spider so that engine will start from key only
as to ford LR engine ecu if no fob needed 10AS can be programmed spider so that engine will start from key only |
10th Jan 2020 10:37am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
My as10 is also programmed so I don't need a fob. Bell Autoservice can do something with the ECU so it doesn't look for the AS10 so you can get rid of it alltogether. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
10th Jan 2020 5:43pm |
Thanks, all. Looks like some good options there. Definitely want rid, so may give BAS a call.
11th Jan 2020 7:43am |
