Home > In Car Electronics > Where to Buy Original Wipac Crystals?
HardCharger
Hi All!
I've decided to replace my QuadOptics headlights as they became a fishbowl for a few weeks when my Defender drowned and there seems to be permanent stains inside the reflector and lenses. Since whole LED assemblies are still out of my price range, I decided to go the Wipac Crystals route. After doing some research, there are many installation posts and photos but no indication of where to buy them. Sad Can anyone point me the right direction on where I can buy honest to goodness Wipac Crystals and not some other looks like brand?
Are there Wipac Crystal assemblies without the position light or are they only available with the position light? I would prefer the assemblies without the position lights as I have the standard look and not the SVX look.
I have the Landreiziger loom but I think the electrician I asked to install it on my behalf wired it to take feed from the battery and not the alternator as indicated in the instructions Mad Is there a difference in the performance if it was done this way as compared to how it's actually supposed to be done? If so, I may have to buy another kit and have a more trusted electrician re-do the wiring to get things done properly.
Thanks in advance for your input and advice. Thumbs Up
Post #808663 4th Jan 2020 6:19am
VVS210
Ypu should be able to buy these from any number of online suppliers as well as over the counter. When I bought mine I got them at my local supplier, Keith Gott in Alton, Hampshire - they have a website & trade worldwide.
Post #808670 4th Jan 2020 8:16am
discomog
Just Google "Wipac Crystal Headlights", lots of Ebay and other suppliers to choose from. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #808675 4th Jan 2020 9:48am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Be careful. I bought what were supposedly genuine Wipac and arrived with tape covering the sidelight bulb holder. I eventually got what I wanted from Bolt on bits.
Post #808695 4th Jan 2020 12:31pm
oneten110
https://www.paddockspares.com/pm678-wipac-...ralia.html It is not a Defender, it is a One_Ten
Post #808833 5th Jan 2020 3:50pm
Re: Where to Buy Original Wipac Crystals?
HardCharger wrote:
... The electrician I asked to install it on my behalf wired it to take feed from the battery and not the alternator as indicated in the instructions Mad Is there a difference in the performance if it was done this way as compared to how it's actually supposed to be done? If so, I may have to buy another kit and have a more trusted electrician re-do the wiring to get things done properly.
No problem.with this at all, and in many ways it is better than connecting to the alternator (something I personally wouldn't do). I suspect that the loom maker opted for the alternator because it is nearer and easier to get to, meaning a shorter cable can be supplied.
Post #808835 5th Jan 2020 4:11pm
Bluest
The loom would have had to extended to wire it from the battery, as no way it will reach in standard form. It should be fine as long as the extension has been done properly with correct gauge wire it will be fine. 2007 110 TDCi Station Wagon XS
Post #808843 5th Jan 2020 4:41pm
ericvv
What's the reason for that?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #808844 5th Jan 2020 4:46pm
oneten110
Had my headlights wired from the alternator (via fuses) for over 15 years without any problems whatsoever It is not a Defender, it is a One_Ten
Post #809157 7th Jan 2020 12:31pm
HardCharger
Hi All!
I took a look at the Bolt on Bits site and they do have Wipac Crystals with no side lights. Upon reading the description, they say the "crystal" lens is polycarbonate and not glass? Is this the same headlight assemblies we're talking about?
Thanks.
Post #809479 9th Jan 2020 2:31am
Eric
In my (OCD electrical) mind... neatness.... keep all the feeds in one place (battery box), and the fuses there also, instead of having feeds here there and everywhere and fuses all over the place.
Post #809489 9th Jan 2020 7:56am
HardCharger wrote:
Hi All!
Thanks.
Yes, that's right. 'Crystal' headlights work on a different principle whereby the beam pattern is determined by the reflector rather than the lens. Darren
Post #809505 9th Jan 2020 8:51am
HardCharger
So these are the go then?
Post #809652 10th Jan 2020 9:26am
Yes. Darren
Post #809668 10th Jan 2020 12:26pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Reading this topic has me a little confused. I was thinking of fitting Wipac Crystals to my Defender so was looking at some YouTube content. From what I’ve seen they seem to be “plug and play” ie remove the old unit and replace with the crystal unit. However I’ve noticed that people have mentioned a new wiring loom and relay from the battery and bypassing the alternator?
What am I missing here, can someone explain the whys and wherefores ?
Post #809692 10th Jan 2020 5:50pm
