![]() | Home > In Car Electronics > Where to Buy Original Wipac Crystals? |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Ypu should be able to buy these from any number of online suppliers as well as over the counter. When I bought mine I got them at my local supplier, Keith Gott in Alton, Hampshire - they have a website & trade worldwide.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
Just Google "Wipac Crystal Headlights", lots of Ebay and other suppliers to choose from. Defender 90XS SW
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
Be careful. I bought what were supposedly genuine Wipac and arrived with tape covering the sidelight bulb holder. I eventually got what I wanted from Bolt on bits.
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
https://www.paddockspares.com/pm678-wipac-...ralia.html It is not a Defender, it is a One_Ten
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
No problem.with this at all, and in many ways it is better than connecting to the alternator (something I personally wouldn't do). I suspect that the loom maker opted for the alternator because it is nearer and easier to get to, meaning a shorter cable can be supplied. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4340 ![]() ![]() ![]() |
The loom would have had to extended to wire it from the battery, as no way it will reach in standard form. It should be fine as long as the extension has been done properly with correct gauge wire it will be fine. 2007 110 TDCi Station Wagon XS
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
What's the reason for that? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Had my headlights wired from the alternator (via fuses) for over 15 years without any problems whatsoever It is not a Defender, it is a One_Ten
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 820 ![]() ![]() ![]() |
Hi All!
I took a look at the Bolt on Bits site and they do have Wipac Crystals with no side lights. Upon reading the description, they say the "crystal" lens is polycarbonate and not glass? Is this the same headlight assemblies we're talking about? Thanks. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
In my (OCD electrical) mind... neatness.... keep all the feeds in one place (battery box), and the fuses there also, instead of having feeds here there and everywhere and fuses all over the place. |
Yes, that's right. 'Crystal' headlights work on a different principle whereby the beam pattern is determined by the reflector rather than the lens. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
So these are the go then?
Yes. Darren
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Reading this topic has me a little confused. I was thinking of fitting Wipac Crystals to my Defender so was looking at some YouTube content. From what I’ve seen they seem to be “plug and play” ie remove the old unit and replace with the crystal unit. However I’ve noticed that people have mentioned a new wiring loom and relay from the battery and bypassing the alternator?
What am I missing here, can someone explain the whys and wherefores ? |
