Home > In Car Electronics > Let’s see your battery box! |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
Doing a bit of work with the battery box with a fuse board for powering a load of bits. (Ignition live or permanent) DRL controller and an ignition live relay for the fuse board.
I’m basically doing all the work for a dual battery system but without the extra battery. Has anyone ‘tidied up’ their battery box and is so do you have any photos. Cheers and happy New year. Pcm |
1st Jan 2020 12:32pm |
Lols lovely ( if these is such a term for a battery box)
I have the same blue sea fuse box. Recommended by mcma. Also have a 100a ignition life thingy. Don’t have too much to add just now, but would rather be prepared. |
1st Jan 2020 4:57pm |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 226 |
Just starting mine
Click image to enlarge Click image to enlarge |
4th Jan 2020 5:52pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2197 |
I have a YRM centre tool tray into which i have a 6 relay box, 12way fusebox with half ignition live fed, high current ignition relay and my voltage sensing relay for the split charge:
Click image to enlarge In my battery box I have two of the no longer available CXV-1000 Enduroline batteries, two albright isolators (one connects the batteries for split charging or self jump starting and the other isolates the winch) as well as a fuse and some diodes: Click image to enlarge Click image to enlarge I have convoluted tubing runs and through panel adaptors which provide wiring routes between the centre tray and two seatbox sides. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
4th Jan 2020 9:56pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
That’s very tidy and impressive Steve 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
4th Jan 2020 10:16pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Thats too neat.
Well jelous Instagram @defender_ventures Empire Tuning - Agent |
4th Jan 2020 11:35pm |
