Home > In Car Electronics > Let’s see your battery box!
PCM
Doing a bit of work with the battery box with a fuse board for powering a load of bits. (Ignition live or permanent) DRL controller and an ignition live relay for the fuse board.
I’m basically doing all the work for a dual battery system but without the extra battery.
Has anyone ‘tidied up’ their battery box and is so do you have any photos.
Cheers and happy New year.
Pcm
Post #808348 1st Jan 2020 12:32pm
bankz5152
Mines full! Split charge fitted so all my aux stuff is in a MUD locker box under the cubby, mote its alot more full and messy now Laughing
Bluesea aux fuse boxes are quality units ot you can get ebay "glow when blow" fuse boxes.
Also got two bus bars behind the dash for switched live items and local switch earths.
Post #808350 1st Jan 2020 12:48pm
PCM
Lols lovely ( if these is such a term for a battery box)
I have the same blue sea fuse box. Recommended by mcma.
Also have a 100a ignition life thingy.
Don’t have too much to add just now, but would rather be prepared.
Post #808381 1st Jan 2020 4:57pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Just starting mine Very Happy
Post #808724 4th Jan 2020 5:52pm
rallysteve
I have a YRM centre tool tray into which i have a 6 relay box, 12way fusebox with half ignition live fed, high current ignition relay and my voltage sensing relay for the split charge:
In my battery box I have two of the no longer available CXV-1000 Enduroline batteries, two albright isolators (one connects the batteries for split charging or self jump starting and the other isolates the winch) as well as a fuse and some diodes:
I have convoluted tubing runs and through panel adaptors which provide wiring routes between the centre tray and two seatbox sides.
Post #808763 4th Jan 2020 9:56pm
Sulisuli
That’s very tidy and impressive Steve Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #808765 4th Jan 2020 10:16pm
bankz5152
Thats too neat. Shocked
Well jelous Laughing
Post #808777 4th Jan 2020 11:35pm
