![]() | Home > V8 > difference between |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
anyone tell me the difference between the SD1 v8 and the Range rover 3.5 v8 .
SD1 was 9:35:1 and Range Rover was 10:5:1 I believe 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
IIRC Range Rover had lower power output due to restrictions in inlet manifolds.
Sdi was the engine to use in your Series + Range Rover diffs because of higher power. Just because you're offended doesn't mean you're right. |
do the RR 4speed box fit the SD1?
Alex 44 Member Since: 05 Sep 2016 Location: Staffordshire Posts: 2 ![]() ![]() |
Sd1 v8 was 9.35 :1
Range Rover was originally 8.13:1 on carbs, until it became efi in 85, then it became the same 9.35:1 it remained at that until the end of production in the P38 The water pump and front covers are different, Range Rovers being up higher so the fan was in the middle of the Radiator. The only ones that had 10.7:1 were fitted in the Rover P5B Coupe. All the Best. |
many thanks for all the information , the engine came out of a Range rover classic but the block number is 10A .
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
The compression ratio in the 4.2 in the Range Rover classic was 8.94 It is not a Defender, it is a One_Ten |
after a bit of looking the first range rover v8 ,were 8.5.1 for the first 1000 , but I think things like alternator etc not sure about the water pump are the same , less anyone knows better .
