Home > V8 > difference between
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
difference between
anyone tell me the difference between the SD1 v8 and the Range rover 3.5 v8 .
Post #806153 14th Dec 2019 2:04pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
SD1 was 9:35:1 and Range Rover was 10:5:1 I believe 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #806157 14th Dec 2019 2:22pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
IIRC Range Rover had lower power output due to restrictions in inlet manifolds.
Sdi was the engine to use in your Series + Range Rover diffs because of higher power. Just because you're offended doesn't mean you're right.
Post #806160 14th Dec 2019 3:32pm
tolley
do the RR 4speed box fit the SD1?
Post #806161 14th Dec 2019 3:44pm
oneten110
Given that the V8 block has the same external dimensions throughout its production. If a gearbox fits one of them it will fit all of them. It is not a Defender, it is a One_Ten
Post #806165 14th Dec 2019 4:31pm
tolley
Thumbs Up thank you
Post #806166 14th Dec 2019 4:32pm
Alex 44
Sd1 v8 was 9.35 :1
Range Rover was originally 8.13:1 on carbs, until it became efi in 85, then it became the same 9.35:1 it remained at that until the end of production in the P38
The water pump and front covers are different, Range Rovers being up higher so the fan was in the middle of the Radiator.
The only ones that had 10.7:1 were fitted in the Rover P5B Coupe.
All the Best.
Post #806234 14th Dec 2019 10:54pm
tolley
many thanks for all the information , the engine came out of a Range rover classic but the block number is 10A .
Post #806278 15th Dec 2019 11:24am
oneten110
Alex 44 wrote:
Sd1 v8 was 9.35 :1
All the Brest.
The compression ratio in the 4.2 in the Range Rover classic was 8.94 It is not a Defender, it is a One_Ten
Post #806312 15th Dec 2019 4:04pm
tolley
after a bit of looking the first range rover v8 ,were 8.5.1 for the first 1000 , but I think things like alternator etc not sure about the water pump are the same , less anyone knows better .
Post #816465 22nd Feb 2020 9:24pm
