Home > Td5 > td5 turbo feed banjo wrench size |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
14mm
Why do you need to make up a wrench? A socket from above or a normal spanner has done the job for me many times. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
5th Nov 2019 8:40pm |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
i installed my VGT and oriented the feed pipe the same as the original one. turns out the one they supplied is longer so i need to loosen the banjo on the oil filter end a bit and rotate it counter clockwise a bit to remove some of the bend in my feed line. when i installed i had to remove the oil filter housing to get the banjo bolt out. i didn't notice the overlength issue until i tried to connect it to the turbo and i don't want to pull everything apart again 04 110 TD5
5th Nov 2019 8:51pm |
