Home > Td5 > td5 turbo feed banjo wrench size |
rallysteve Member Since: 10 Feb 2014 Location: South Yorks Posts: 2194 |
14mm
Why do you need to make up a wrench? A socket from above or a normal spanner has done the job for me many times. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread Mobile Diesel Heater Build Thread |
5th Nov 2019 7:40pm |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
i installed my VGT and oriented the feed pipe the same as the original one. turns out the one they supplied is longer so i need to loosen the banjo on the oil filter end a bit and rotate it counter clockwise a bit to remove some of the bend in my feed line. when i installed i had to remove the oil filter housing to get the banjo bolt out. i didn't notice the overlength issue until i tried to connect it to the turbo and i don't want to pull everything apart again 04 110 TD5
5th Nov 2019 7:51pm |
