Home > Td5 > td5 turbo feed banjo wrench size
Ndamico
Canada 2004 Defender 110 Td5 CSW Alpine White
trying to make a wrench to loosen the banjo bolt to change its orientation. is it a 15mm or 14mm head?
thanks! 04 110 TD5
Post #800910 5th Nov 2019 7:04pm
rallysteve
14mm
Why do you need to make up a wrench? A socket from above or a normal spanner has done the job for me many times.
Post #800920 5th Nov 2019 7:40pm
Ndamico
i installed my VGT and oriented the feed pipe the same as the original one. turns out the one they supplied is longer so i need to loosen the banjo on the oil filter end a bit and rotate it counter clockwise a bit to remove some of the bend in my feed line. when i installed i had to remove the oil filter housing to get the banjo bolt out. i didn't notice the overlength issue until i tried to connect it to the turbo and i don't want to pull everything apart again Smile 04 110 TD5
Post #800925 5th Nov 2019 7:51pm
