Home > Td5 > Waterpump to thermostat hose - part number |
3rd Nov 2019 6:14pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5740 |
Cheers DS. Mmmm there are 3 number 3's to choose from.
PCH116010 PCH117190 PCH117191 I think I can discount; PCH117190 - Don't the hose that T's off PCH117191 - thats a 2004 MY (i am 1999) Leaves me with PCH116010 but on googling, I am now not sure as this appears to be superseded by PCH117190 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
3rd Nov 2019 6:31pm |
PCH116010
Chassis VINs to XA169398 (1999 MY) PCH117190 Chassis VINs from XA169399 to 4A673266 (1999 to 2004 MY) Defender |
3rd Nov 2019 6:40pm |
I am the first range of VIN numbers. That's the part I am after but appears hard to find?[/list] 1999 Defender TD5 110
3rd Nov 2019 6:46pm |
This part has been superseded Use PCH117190 as you stated
3rd Nov 2019 7:56pm |
I think this hunt could get tricky. 1999 Defender TD5 110
3rd Nov 2019 9:39pm |
thing is your 10p engine cooling system has same parts i.e. round fuel cooler as 03 15p engine coolant pump and thermostat all in same place only time pipe work change then squire type fuel cooler added
But of cores EGR cooler but it gets coolant from the oil cooler |
3rd Nov 2019 9:59pm |
Cheers. Is that what the extra T'd off pipe is for the EGR cooler? 1999 Defender TD5 110
3rd Nov 2019 10:54pm |
trying to work out what the extra T'd off pipe is for, if stop raining i have a look my 53 plate and report back
4th Nov 2019 9:33am |
Cheers DS.
Here is mine Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
4th Nov 2019 9:39am |
Waterpump to thermostat hose on 53 90 has T'd off pipe witch runs a long front x member and up driver side of the engine inside engine AV and up to the fuel cooler back end
Click image to enlarge |
4th Nov 2019 10:48am |
Thanks DS. Interesting. My fuel cooler is fed via another pipe - which one, I am not sure. 1999 Defender TD5 110
4th Nov 2019 10:59am |
Click image to enlarge PCH117190 this is shown with metal t pieces and clips remove smaller pipe and fit blanking cap in its place |
4th Nov 2019 11:22am |
That is certainly an option DS. Or a straight through tube. 1999 Defender TD5 110
4th Nov 2019 11:33am |
