![]() | Home > Td5 > Waterpump to thermostat hose - part number |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
Cheers DS. Mmmm there are 3 number 3's to choose from.
PCH116010 PCH117190 PCH117191 I think I can discount; PCH117190 - Don't the hose that T's off PCH117191 - thats a 2004 MY (i am 1999) Leaves me with PCH116010 but on googling, I am now not sure as this appears to be superseded by PCH117190 ![]() Regards John M0VAZ Econet Station 48 no clock |
PCH116010
Chassis VINs to XA169398 (1999 MY) PCH117190 Chassis VINs from XA169399 to 4A673266 (1999 to 2004 MY) Defender |
I am the first range of VIN numbers. That's the part I am after but appears hard to find?[/list] 1999 Defender TD5 110
This part has been superseded Use PCH117190 as you stated
I think this hunt could get tricky. 1999 Defender TD5 110
thing is your 10p engine cooling system has same parts i.e. round fuel cooler as 03 15p engine coolant pump and thermostat all in same place only time pipe work change then squire type fuel cooler added
But of cores EGR cooler ![]() |
Cheers. Is that what the extra T'd off pipe is for the EGR cooler? 1999 Defender TD5 110
trying to work out what the extra T'd off pipe is for, if stop raining i have a look my 53 plate and report back
Cheers DS.
Here is mine ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Waterpump to thermostat hose on 53 90 has T'd off pipe witch runs a long front x member and up driver side of the engine inside engine AV and up to the fuel cooler back end
Thanks DS. Interesting. My fuel cooler is fed via another pipe - which one, I am not sure. 1999 Defender TD5 110
![]() Click image to enlarge PCH117190 this is shown with metal t pieces and clips remove smaller pipe and fit blanking cap in its place ![]() |
That is certainly an option DS. Or a straight through tube. 1999 Defender TD5 110
