Home > Td5 > Waterpump to thermostat hose - part number
excossack
Does anyone have the part number for the water pump to thermostat hose please? I think I might have ordered the wrong hose! (TD5 110 / 1999 vintage) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #800602 3rd Nov 2019 5:58pm
dorsetsmith
Post #800607 3rd Nov 2019 6:14pm
excossack
Cheers DS. Mmmm there are 3 number 3's to choose from.
PCH116010
PCH117190
PCH117191
I think I can discount;
PCH117190 - Don't the hose that T's off
PCH117191 - thats a 2004 MY (i am 1999)
Leaves me with PCH116010 but on googling, I am now not sure as this appears to be superseded by PCH117190 Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #800611 3rd Nov 2019 6:31pm
dorsetsmith
PCH116010
Chassis VINs to XA169398 (1999 MY)
PCH117190
Chassis VINs from XA169399 to 4A673266 (1999 to 2004 MY)
Defender
Post #800617 3rd Nov 2019 6:40pm
excossack
I am the first range of VIN numbers. That's the part I am after but appears hard to find?[/list] 1999 Defender TD5 110
Regards
John M0VAZ
Post #800619 3rd Nov 2019 6:46pm
dorsetsmith
This part has been superseded Use PCH117190 as you stated
Post #800628 3rd Nov 2019 7:56pm
excossack
I think this hunt could get tricky. 1999 Defender TD5 110
Regards
John M0VAZ
Post #800653 3rd Nov 2019 9:39pm
dorsetsmith
thing is your 10p engine cooling system has same parts i.e. round fuel cooler as 03 15p engine coolant pump and thermostat all in same place only time pipe work change then squire type fuel cooler added
But of cores EGR cooler Exclamation but it gets coolant from the oil cooler
Post #800655 3rd Nov 2019 9:59pm
excossack
Cheers. Is that what the extra T'd off pipe is for the EGR cooler? 1999 Defender TD5 110
Regards
John M0VAZ
Post #800678 3rd Nov 2019 10:54pm
dorsetsmith
trying to work out what the extra T'd off pipe is for, if stop raining i have a look my 53 plate and report back
Post #800699 4th Nov 2019 9:33am
excossack
Cheers DS.
Here is mine
Regards
John M0VAZ
Post #800701 4th Nov 2019 9:39am
dorsetsmith
Waterpump to thermostat hose on 53 90 has T'd off pipe witch runs a long front x member and up driver side of the engine inside engine AV and up to the fuel cooler back end
Post #800706 4th Nov 2019 10:48am
excossack
Thanks DS. Interesting. My fuel cooler is fed via another pipe - which one, I am not sure. 1999 Defender TD5 110
Regards
John M0VAZ
Post #800707 4th Nov 2019 10:59am
dorsetsmith
PCH117190
this is shown with metal t pieces and clips remove smaller pipe and fit blanking cap in its place Idea
Post #800710 4th Nov 2019 11:22am
excossack
That is certainly an option DS. Or a straight through tube. 1999 Defender TD5 110
Regards
John M0VAZ
Post #800712 4th Nov 2019 11:33am
