Home > Technical > Engine management light
sjc501
Hi all .I had to disconnect my battery on my 2013 puma and recharge it .When I charged and started my engine management light and the the little red puff of smoke light . Worth noting these where a previous fault caused by split hose I had replaced and code cleared . Is it possible disconnecting battery has caused this again. Car now in limo home mode .
Post #795218 26th Sep 2019 3:44pm
Co1
Sounds like the DPF light?
Post #795225 26th Sep 2019 5:00pm
sjc501
Would that cause an engine management light and limp mode ?
Post #795229 26th Sep 2019 5:15pm
sjc501
Hi Looks like you are right .Got it plugged in and DPF fault showed uo .Need to get it regained whatever that means?
Post #795372 27th Sep 2019 11:28am
dorsetsmith
RED DPF Full is externally controlled and needs to be reset also check for more DTC
Post #795393 27th Sep 2019 1:07pm
sjc501
No idea .How do I get it reset . I had codes turn of by kiwis fit but the def light came back on .
Post #795447 27th Sep 2019 4:53pm
dorsetsmith
if you had the red DPF Full lamp reset but it came back on
1. one DPF is full will need cleaning or replacing
2. DPF presser differential sensor has fail or pipe work to the presser differential sensor is block
Post #795456 27th Sep 2019 5:23pm
sjc501
I had Kwik fit check the fault code which said DPF fault .Im finding thus a bit strange as I had to Disconnect my battery to recharge as I left lights on overnight . After trying to start I charged it properly .Car started after I reconnected but this fault flagged up . Just wondering is this a coincidence
Post #795471 27th Sep 2019 6:14pm
90 Dreamer
Have had other vehicles that throw random codes due to a low voltage situation......
Post #795481 27th Sep 2019 7:17pm
sjc501
Thanks .Thats why I went to Kwik fit to hopefully remove codes and start again .But they came back the DPF and Engine Management light
Post #795500 27th Sep 2019 8:31pm
NickMc
My advice is take it anywhere else but Kwik fit Shocked
Clearing codes in the hope of a fix is a bad practice. Suggest you take it to a specialist who can help and diagnose your problem properly.
They are suggesting a DPF regeneration. This may be down to your driving style/short journeys.
Post #795823 29th Sep 2019 4:57pm
