![]() | Home > Technical > Engine management light |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3787
Sounds like the DPF light?
| sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148
Would that cause an engine management light and limp mode ?
Hi Looks like you are right .Got it plugged in and DPF fault showed uo .Need to get it regained whatever that means?
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
RED DPF Full is externally controlled and needs to be reset also check for more DTC
No idea .How do I get it reset . I had codes turn of by kiwis fit but the def light came back on .
if you had the red DPF Full lamp reset but it came back on
1. one DPF is full will need cleaning or replacing 2. DPF presser differential sensor has fail or pipe work to the presser differential sensor is block |
I had Kwik fit check the fault code which said DPF fault .Im finding thus a bit strange as I had to Disconnect my battery to recharge as I left lights on overnight . After trying to start I charged it properly .Car started after I reconnected but this fault flagged up . Just wondering is this a coincidence
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
Have had other vehicles that throw random codes due to a low voltage situation......
Thanks .Thats why I went to Kwik fit to hopefully remove codes and start again .But they came back the DPF and Engine Management light
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
My advice is take it anywhere else but Kwik fit
Clearing codes in the hope of a fix is a bad practice. Suggest you take it to a specialist who can help and diagnose your problem properly. They are suggesting a DPF regeneration. This may be down to your driving style/short journeys. |
| All times are GMT |
