Home > Technical > Engine management light |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3618 |
Sounds like the DPF light?
26th Sep 2019 5:00pm |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 |
Would that cause an engine management light and limp mode ?
26th Sep 2019 5:15pm |
Hi Looks like you are right .Got it plugged in and DPF fault showed uo .Need to get it regained whatever that means?
27th Sep 2019 11:28am |
RED DPF Full is externally controlled and needs to be reset also check for more DTC
27th Sep 2019 1:07pm |
No idea .How do I get it reset . I had codes turn of by kiwis fit but the def light came back on .
27th Sep 2019 4:53pm |
if you had the red DPF Full lamp reset but it came back on
1. one DPF is full will need cleaning or replacing 2. DPF presser differential sensor has fail or pipe work to the presser differential sensor is block |
27th Sep 2019 5:23pm |
I had Kwik fit check the fault code which said DPF fault .Im finding thus a bit strange as I had to Disconnect my battery to recharge as I left lights on overnight . After trying to start I charged it properly .Car started after I reconnected but this fault flagged up . Just wondering is this a coincidence
27th Sep 2019 6:14pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
Have had other vehicles that throw random codes due to a low voltage situation......
27th Sep 2019 7:17pm |
Thanks .Thats why I went to Kwik fit to hopefully remove codes and start again .But they came back the DPF and Engine Management light
27th Sep 2019 8:31pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
My advice is take it anywhere else but Kwik fit
Clearing codes in the hope of a fix is a bad practice. Suggest you take it to a specialist who can help and diagnose your problem properly. They are suggesting a DPF regeneration. This may be down to your driving style/short journeys. |
29th Sep 2019 4:57pm |
