![]() | Home > Td5 > Tdci lt230 into a td5?? |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
It depends on what you do with the car.
If it's just driving around on tarmac, the 1.2 will make is easier. If you are doing a lot of towing, then maybe the stock ratio works out better. I've swapped over to a disco box and never looked back, it's really a better drive and less drone on the motorway. Sure, a remap always will make it less laborious when pulling away. If you have cruise control enabled, it won't work after the swap until you put in something like a speedohealer as the RPM of the engine will not match the t-box road speed pulse wave so the cruise control won't latch. The TdCi transfer box is 1.211 while a the disco box is 1.222, won't make a big difference, but technically that's what it is. The defender has migrated, leaving the owner behind. |
