Home > Td5 > Tdci lt230 into a td5??
Page 2 of 2 <12
landy andy
I’m surprised reading this.
I’ve had a Td5 90 that I swapped the gearing on (so drove it with standard, and regeared), then a crappy Tdci, and now a Td5 with the standard gearing, and very much thinking I need to regear it as all the gears are too low, and that’s on a 110.
On the times I’ve towed heavy stuff, low range, then flick across to high if required.
Wowed by the idea I’ve got the correct gearing currently
Ohhh and I don’t do long runs or motorways with it.
Post #784725 3rd Aug 2019 9:48pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
It depends on what you do with the car.
If it's just driving around on tarmac, the 1.2 will make is easier. If you are doing a lot of towing, then maybe the stock ratio works out better.
I've swapped over to a disco box and never looked back, it's really a better drive and less drone on the motorway.
Sure, a remap always will make it less laborious when pulling away.
If you have cruise control enabled, it won't work after the swap until you put in something like a speedohealer as the RPM of the engine will not match the t-box road speed pulse wave so the cruise control won't latch.
The TdCi transfer box is 1.211 while a the disco box is 1.222, won't make a big difference, but technically that's what it is. The defender has migrated, leaving the owner behind.
Post #784849 4th Aug 2019 2:40pm
Page 2 of 2 <12
