![]() | Home > Off Topic > 2007 Specialized FSR XC Pro advice please |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1643 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last edited by Barneyboy on 28th Jul 2019 3:27pm. Edited 1 time in total |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Component Highlights: FSR M4 butted frame w/ ORE down tube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel Fox Triad shock Rock Shox Reba SL fork Avid Juicy 3, hydraulic disc brakes SRAM X-9, 9-speed, long cage rear derailleur Custom Shimano Hollowtech crankset, Octalink XT Spline Specialized Resolution 26x2.0" tires Full Specification: FRAME FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.0x1.6" FORK Rock Shox Reba SL, 100mm, air spring, lock out, ext rebound adj, alloy steerer HEADSET 1 1/8" threadless, black steel cups, loose ball bearings w/ seals STEM Specialized adjustable rise, OS 31.8, 3D forged HANDLEBARS Specialized XC low rise 31.8mm OS bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm width GRIPS Specialized MTB, dual density FRONT BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor REAR BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 185mm rotor BRAKE LEVERS Avid Juicy 3 hydraulic FRONT DERAILLEUR Shimano FD-M580, LX, top swing, dual pull, 34.9mm clamp REAR DERAILLEUR SRAM X-9, 9-speed, long cage SHIFT LEVERS SRAM X-7, Aluminium trigger 9-speed CASSETTE Shimano HG50, 9-speed, 11/34t CHAIN Shimano HG73 CRANKSET Custom Shimano Hollowtech, Octalink XT Spline CHAINRINGS 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm BOTTOM BRACKET Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline PEDALS Shimano 505 SPD RIMS Mavic X117 Disc, 26", 32h, black, presta valve FRONT HUB Specialized disc, sealed cartridge bearing, high/low flange, 32h REAR HUB Shimano M-475L disc, 32h, 8/9-speed, alloy QR SPOKES 1.8mm stainless, black, brass nipples FRONT TYRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound REAR TYRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound TUBES Specialized Ultralight 26x2.0", presta SADDLE Specialized BG MTB, hollow Cro-Mo rails SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm SEAT BINDER Alloy collar with QR, 34.9mm clamp ID, black NOTES Protective clear coat, derailleur hanger, reflectors, owners manual |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 138 ![]() ![]() ![]() |
Nice bike.
I’ve been looking for a new (old) MTB - would have made you an offer but it’s too small for me. Prices for similar seem to range from £200-£400 depending on condition. I’m looking for a lighter 26” XC style as all MTB’s seem to have gone 650b or 29” and full on chunky 😕 . As I’ve got older I’ve lost my bottle on the gnarly stuff so just need something that’s not going to waste me on the uphills ![]() 2003 D2 Td5 Black [SOLD] |
Hi DG123 Thank you for the heads up re price guide
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
Good luck with your sale, you’ve done a remarkable job of keeping it so well maintained given it’s age. Someone’s going to get a bargain, second hand sales have taken a ruthless hit in the past few years due to tech advancements. I’ve been harping on about 31” wheels for years, jokingly I’ll add - doesn’t sound so far fetched these days mind!!
Hi zippo87 thank you although I do have to say it was helped by the quality of the bike as well, after reading reviews at the time it was made very clear that the 2007 year model was the one to go for as the 2008 had from memory different front shocks and brakes it took a bit of phoning around but I found this one at Cycleopedia in Watford it was their last one as well, haha 31” wheels I bet you’re not far off you know
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7938 ![]() ![]() ![]() |
Great looking bike in cracking condition for it's age! If I were closer I might be tempted to make you a cheeky offer, but I'm going to resist.
Out of interest what height person would this suit? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Hi JOW240725 Thank you, i am 5'11 and its fine for me, although any taller i would say a large is required
Hi All, Thank you for all of you're comments regarding this, it is now in the For Sale section
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Barney, long time no talk
![]() Lovely keep bike mate, I brought new and still have my 2007 stumpjumper, the bikes changed considerably in 2008, I was alway glad I brought a 2007 and not held out for the 2008 as the build quality’s was reportedly dropped on the 2008 model. Good luck with the sale. Just can’t own a 7th bike ![]() ![]() |
Hi Tack how are you
