Home > Off Topic > 2007 Specialized FSR XC Pro advice please
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi I’ve owned my 2007 Specialized FSR XC pro (size Medium )from new (12th January 2008) and have made a decision to move it on but I have no clue if it has any value or not, I know a lot of you are in to mountain biking and would really appreciate some advice please, it’s in overall very good condition and the only things I’ve replaced are the wheel rims and the bottom crank the rear wheel requires replacing as the hub bearing has failed but there are a spare set of rims ( rear with cassette and avid disc already fitted ) it’s a 27 speed , I have the original receipt and all the book pack, it’s fitted with Town and Country tires with slime inner tubes as I was using this to commute to work.personally I think it is in very nice condition and with it being 11 years old I hope this shows that it has been well cared for as can be seen i paid £970 for it
. Thumbs Up Paul
Post #783611 28th Jul 2019 3:10pm
Barneyboy
Post #783612 28th Jul 2019 3:14pm
Barneyboy
Post #783613 28th Jul 2019 3:18pm
Barneyboy
Component Highlights:
FSR M4 butted frame w/ ORE down tube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
Fox Triad shock
Rock Shox Reba SL fork
Avid Juicy 3, hydraulic disc brakes
SRAM X-9, 9-speed, long cage rear derailleur
Custom Shimano Hollowtech crankset, Octalink XT Spline
Specialized Resolution 26x2.0" tires
Full Specification:
FRAME FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
REAR SHOCK Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.0x1.6"
FORK Rock Shox Reba SL, 100mm, air spring, lock out, ext rebound adj, alloy steerer
HEADSET 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
STEM Specialized adjustable rise, OS 31.8, 3D forged
HANDLEBARS Specialized XC low rise 31.8mm OS bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm width
GRIPS Specialized MTB, dual density
FRONT BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 185mm rotor
BRAKE LEVERS Avid Juicy 3 hydraulic
FRONT DERAILLEUR Shimano FD-M580, LX, top swing, dual pull, 34.9mm clamp
REAR DERAILLEUR SRAM X-9, 9-speed, long cage
SHIFT LEVERS SRAM X-7, Aluminium trigger 9-speed
CASSETTE Shimano HG50, 9-speed, 11/34t
CHAIN Shimano HG73
CRANKSET Custom Shimano Hollowtech, Octalink XT Spline
CHAINRINGS 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline
PEDALS Shimano 505 SPD
RIMS Mavic X117 Disc, 26", 32h, black, presta valve
FRONT HUB Specialized disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB Shimano M-475L disc, 32h, 8/9-speed, alloy QR
SPOKES 1.8mm stainless, black, brass nipples
FRONT TYRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound
REAR TYRE Specialized Resolution 26x2.0", 120TPI, aramid bead, dual compound
TUBES Specialized Ultralight 26x2.0", presta
SADDLE Specialized BG MTB, hollow Cro-Mo rails
SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER Alloy collar with QR, 34.9mm clamp ID, black
NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
Post #783616 28th Jul 2019 3:22pm
DG123
Nice bike.
I’ve been looking for a new (old) MTB - would have made you an offer but it’s too small for me. Prices for similar seem to range from £200-£400 depending on condition.
I’m looking for a lighter 26” XC style as all MTB’s seem to have gone 650b or 29” and full on chunky 😕 . As I’ve got older I’ve lost my bottle on the gnarly stuff so just need something that’s not going to waste me on the uphills Laughing 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #783646 28th Jul 2019 6:39pm
Barneyboy
Hi DG123 Thank you for the heads up re price guide Thumbs Up , I have bought myself a new Specialized Camber comp 29er in Dec 2018 and love it so much so that this one is not being used now, shame about the size, I’m not in to the really gnarley stuff as I had 4 op’s on my shoulder in August last year but have recovered 100% and have been really enjoying the Evans ride it events and I live a few hundred yards from the ridgeway so use that a fair bit as well. I hope you find what you’re looking for Thumbs Up cheers Paul
Post #783649 28th Jul 2019 7:00pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
Good luck with your sale, you’ve done a remarkable job of keeping it so well maintained given it’s age. Someone’s going to get a bargain, second hand sales have taken a ruthless hit in the past few years due to tech advancements. I’ve been harping on about 31” wheels for years, jokingly I’ll add - doesn’t sound so far fetched these days mind!!
Post #783708 29th Jul 2019 3:05am
Barneyboy
Hi zippo87 thank you although I do have to say it was helped by the quality of the bike as well, after reading reviews at the time it was made very clear that the 2007 year model was the one to go for as the 2008 had from memory different front shocks and brakes it took a bit of phoning around but I found this one at Cycleopedia in Watford it was their last one as well, haha 31” wheels I bet you’re not far off you know Thumbs Up cheers Paul
Post #783714 29th Jul 2019 6:31am
JOW240725
Great looking bike in cracking condition for it's age! If I were closer I might be tempted to make you a cheeky offer, but I'm going to resist.
Out of interest what height person would this suit? James
Instagram @suffolk_rovers
Post #783749 29th Jul 2019 10:55am
Barneyboy
Hi JOW240725 Thank you, i am 5'11 and its fine for me, although any taller i would say a large is required Thumbs Up cheers Paul
Post #783768 29th Jul 2019 12:20pm
Barneyboy
Hi All, Thank you for all of you're comments regarding this, it is now in the For Sale section Thumbs Up cheers Paul
Post #783797 29th Jul 2019 2:55pm
TACK
Barney, long time no talk Thumbs Up
Lovely keep bike mate, I brought new and still have my 2007 stumpjumper, the bikes changed considerably in 2008, I was alway glad I brought a 2007 and not held out for the 2008 as the build quality’s was reportedly dropped on the 2008 model.
Good luck with the sale. Just can’t own a 7th bike Mr. Green
Thumbs Up
Post #784130 30th Jul 2019 9:12pm
Barneyboy
Hi Tack how are you Thumbs Up I know what you’re saying but I really need the space and am now riding off road to work and loving the new bike so much so the time has come to move it on, it’s been a fantastic ride and i will be sad to see it go hey I even went for a little ride yesterday evening on it as it looks like it might of sold Thumbs Up cheers Paul
Post #784156 31st Jul 2019 6:45am
