Home > In Car Electronics > Hazard switch problem |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 331 |
Almost certainly an earth issue!
14th Jul 2019 2:23pm |
The switch itself doesn’t flash and if your lights are on it should be at full brightness all sounds right to me. Ray
14th Jul 2019 6:03pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
Thank you both.
Could you remember that ray or did you have to go outside and check?🤣 2002 110 td5 |
14th Jul 2019 6:30pm |
I had to check Ray
14th Jul 2019 6:43pm |
Depends what model and what switch!
As long as there is a flashing light inside on the dash somewhere and all the indicators are flashing, then the job is a good'un! |
14th Jul 2019 8:41pm |
