Home > In Car Electronics > Hazard switch problem
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Hi all
I have just put my dash back together after a work light install and noticed that my hazard warning switch does not flash even though the indicators work correctly. It also illuminates when the lights are switched on, but at full brightness rather than just the background switch illumination.
Anybody any thoughts on what is causing this?
Ta 2002 110 td5
Post #781439 14th Jul 2019 12:21pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Almost certainly an earth issue!
Post #781450 14th Jul 2019 2:23pm
mk1collector
The switch itself doesn’t flash and if your lights are on it should be at full brightness Thumbs Up all sounds right to me. Ray
My build thread
Post #781472 14th Jul 2019 6:03pm
Jimb1978
Thank you both.
Could you remember that ray or did you have to go outside and check?🤣 2002 110 td5
Post #781475 14th Jul 2019 6:30pm
mk1collector
I had to check Whistle Rolling with laughter Ray
My build thread
Post #781477 14th Jul 2019 6:43pm
SteveK
Depends what model and what switch!
As long as there is a flashing light inside on the dash somewhere and all the indicators are flashing, then the job is a good'un!
Post #781483 14th Jul 2019 8:41pm
