![]() | Home > In Car Electronics > Hazard switch problem |
| SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 336
Almost certainly an earth issue!
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
The switch itself doesn’t flash and if your lights are on it should be at full brightness
| Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808
Thank you both.
Could you remember that ray or did you have to go outside and check?🤣 2002 110 td5 |
I had to check
Depends what model and what switch!
As long as there is a flashing light inside on the dash somewhere and all the indicators are flashing, then the job is a good'un! |
