![]() | Home > Maintenance & Modifications > Homemade Puma dual battery tray |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 ![]() ![]() ![]() |
Looks like a nifty solution. Well done.
Just a thought... looks a little "light" to me to take the load of 2 batteries and offroad vibration and loadings. But I'm no expert on these things... I assume you have mimicked available commercial solutions so I'm probably off track! Cheers Mike |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
I did wonder if it would be a bit floppy and could add some extra strengthening if needed, but once I got it in with the batteries on its rock solid. It’s mostly 4mm steel so fairly chunky. I’ll put a picture up with the batteries in later. 2007 110 TDCi Station Wagon XS
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Nice!
4mm steel... ok that will be fine. Looked thinner gauge in the photos!
On reflection overnight, I’m going to take it out make some mods to it to incorporate a battery clamp. I was going to use a ratchet strap but going for something more solid. 2007 110 TDCi Station Wagon XS
Here is the new and improved MK1.5 version, with added battery securingness.
![]() Click image to enlarge ![]() Click image to enlarge 2007 110 TDCi Station Wagon XS |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Awesome
