Home > Maintenance & Modifications > Homemade Puma dual battery tray |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
Looks like a nifty solution. Well done.
Just a thought... looks a little "light" to me to take the load of 2 batteries and offroad vibration and loadings. But I'm no expert on these things... I assume you have mimicked available commercial solutions so I'm probably off track! Cheers Mike |
12th May 2019 9:07am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I did wonder if it would be a bit floppy and could add some extra strengthening if needed, but once I got it in with the batteries on its rock solid. It’s mostly 4mm steel so fairly chunky. I’ll put a picture up with the batteries in later. 2007 110 TDCi Station Wagon XS
12th May 2019 9:25am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2232 |
Nice! > 110 XS Double Cab
> Instagram @simonlanemind |
12th May 2019 10:37am |
4mm steel... ok that will be fine. Looked thinner gauge in the photos!
12th May 2019 11:09am |
On reflection overnight, I’m going to take it out make some mods to it to incorporate a battery clamp. I was going to use a ratchet strap but going for something more solid. 2007 110 TDCi Station Wagon XS
12th May 2019 12:51pm |
Here is the new and improved MK1.5 version, with added battery securingness.
Click image to enlarge Click image to enlarge 2007 110 TDCi Station Wagon XS |
15th May 2019 6:35pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Awesome
15th May 2019 9:14pm |
