Home > Maintenance & Modifications > Homemade Puma dual battery tray
Bluest
Introducing patented Mk1 Bluest Puma Dual Battery Tray! Finely crafting from 3 bits of scrap, cut up and together with a welder then sloppily hand painted in chassis black. Fits to the existing battery tray mounting holes and allows the fitment of two standard size batteries side by side.
This is it in position. Please excuse the filth, everything is covered in Dinitrol.
 2007 110 TDCi Station Wagon XS
Post #772686 11th May 2019 9:17pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Looks like a nifty solution. Well done.
Just a thought... looks a little "light" to me to take the load of 2 batteries and offroad vibration and loadings. But I'm no expert on these things... I assume you have mimicked available commercial solutions so I'm probably off track!
Mike
Post #772734 12th May 2019 9:07am
Bluest
I did wonder if it would be a bit floppy and could add some extra strengthening if needed, but once I got it in with the batteries on its rock solid. It’s mostly 4mm steel so fairly chunky. I’ll put a picture up with the batteries in later. 2007 110 TDCi Station Wagon XS
Post #772737 12th May 2019 9:25am
hank
Post #772747 12th May 2019 10:37am
Mike_E
4mm steel... ok that will be fine. Looked thinner gauge in the photos!
Thumbs Up
Post #772751 12th May 2019 11:09am
Bluest
On reflection overnight, I’m going to take it out make some mods to it to incorporate a battery clamp. I was going to use a ratchet strap but going for something more solid. 2007 110 TDCi Station Wagon XS
Post #772760 12th May 2019 12:51pm
Bluest
Here is the new and improved MK1.5 version, with added battery securingness.
Post #773270 15th May 2019 6:35pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Awesome
Post #773294 15th May 2019 9:14pm
