![]() | Home > Td5 > Removing gearbox.... starter off? |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
All need to come off, was doing it last weekend. One at the back is a stud coming from the gearbox with a nut holding on the starter
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Great thanks
plus good time to check starter contacts with it off
I'll add that to the never ending list of stuff that I need to take a look at whilst I'm under there
engine mounts change clutch slave cyl exhaust manifold gasket air filter leaking rocker cover leaking core plug (under exhaust manifold) clutch spigot bush transfer box oil leak cut a chunk out of the gearbox crossmember to clear the t/box RH mounting rubber (I built this with a crossmember instead of the chassis welded on mounts) I'm sure more will follow.... roll on when I get a G.... ![]() |
