Home > Td5 > Removing gearbox.... starter off? |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
All need to come off, was doing it last weekend. One at the back is a stud coming from the gearbox with a nut holding on the starter
12th Apr 2019 8:55pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Great thanks
12th Apr 2019 9:15pm |
plus good time to check starter contacts with it off
12th Apr 2019 9:19pm |
I'll add that to the never ending list of stuff that I need to take a look at whilst I'm under there
engine mounts change clutch slave cyl exhaust manifold gasket air filter leaking rocker cover leaking core plug (under exhaust manifold) clutch spigot bush transfer box oil leak cut a chunk out of the gearbox crossmember to clear the t/box RH mounting rubber (I built this with a crossmember instead of the chassis welded on mounts) I'm sure more will follow.... roll on when I get a G.... |
12th Apr 2019 9:23pm |
