![]() | Home > Technical > Rear window trim fixings? |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
From memory, originally the fixings were bolts into captive nut plates (the rectangular part in your first diagram), which slotted behind the angles structure along the top of the tub. Later, these were replaced with fir tree fixings. Darren
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
Mine simply has the Fir Tree fitting that push through into holes drilled in the frame.
| deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 267
Ah brilliant thanks, thats what I was hoping.
I've measured the fir tree needed and I think its item no. EZM100340LNF but now I can only find these for sale on ebay and for 3 it will cost £13.94 |
Wow that's not cheap!
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
That part is obsolete, the new part number is AWR2539LNF.
Rimmers sell them for £1.58 each. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Ah thanks Bob, I've managed to find some for the range rover P38 seat base which "should" be the same for 10 for £2.89, if those don't work I'll give Rimmers a try
| All times are GMT |
