Home > Technical > Rear window trim fixings?
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
Hi all,
I just bought some second hand window trim which I'm wanting to fix to my hardtop and I'm trying to work out which fixing I need.
From the picture above I see that theres what looks like a bracket, screw and washer needed to fix the bottom of the trim, but I can't find any item numbers for the same in the following picture, have these been replaced with the fir trees (No. 20?) (EZM100340LNF) and if so do I still need some kind of bracket for the fir trees to fix into?
Thanks Thumbs Up
Post #767584 8th Apr 2019 11:20am
From memory, originally the fixings were bolts into captive nut plates (the rectangular part in your first diagram), which slotted behind the angles structure along the top of the tub. Later, these were replaced with fir tree fixings. Darren
Post #767585 8th Apr 2019 11:32am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Mine simply has the Fir Tree fitting that push through into holes drilled in the frame.
Post #767586 8th Apr 2019 11:34am
deaallen
Ah brilliant thanks, thats what I was hoping.
I've measured the fir tree needed and I think its item no. EZM100340LNF but now I can only find these for sale on ebay and for 3 it will cost £13.94 Shocked
Post #767590 8th Apr 2019 11:54am
boxoftricks
Wow that's not cheap!
Post #767595 8th Apr 2019 12:07pm
bob neville
That part is obsolete, the new part number is AWR2539LNF.
Rimmers sell them for £1.58 each.
2013 Defender 90 CSW - sold
Post #767607 8th Apr 2019 1:11pm
deaallen
Ah thanks Bob, I've managed to find some for the range rover P38 seat base which "should" be the same for 10 for £2.89, if those don't work I'll give Rimmers a try
Post #767608 8th Apr 2019 1:15pm
