Home > Technical > Rear window trim fixings? |
From memory, originally the fixings were bolts into captive nut plates (the rectangular part in your first diagram), which slotted behind the angles structure along the top of the tub. Later, these were replaced with fir tree fixings. Darren
8th Apr 2019 11:32am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
Mine simply has the Fir Tree fitting that push through into holes drilled in the frame.
8th Apr 2019 11:34am |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 264 |
Ah brilliant thanks, thats what I was hoping.
I've measured the fir tree needed and I think its item no. EZM100340LNF but now I can only find these for sale on ebay and for 3 it will cost £13.94 |
8th Apr 2019 11:54am |
Wow that's not cheap!
8th Apr 2019 12:07pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
That part is obsolete, the new part number is AWR2539LNF.
Rimmers sell them for £1.58 each. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
8th Apr 2019 1:11pm |
Ah thanks Bob, I've managed to find some for the range rover P38 seat base which "should" be the same for 10 for £2.89, if those don't work I'll give Rimmers a try
8th Apr 2019 1:15pm |
